barryogen wrote:slip on ones may have to be too, but I'm not sure.
postfach wrote:Um, pretty sure your wheels are supposed to fit tight around the ring at the center of the hub, too, so if you put slip on spacers on, the amount of overlap is going to be reduced lots/to nothing, and then all the weight is on the studs, and they're not designed for that.
