p/s bypass ae92
p/s bypass ae92
Postby LOWDWN » Wed Mar 18, 2009 11:11 pm
who has removed power steering from there corolla
-can you get a non ps rack from a xl type corolla?
or
-can you run a feed loop for fluid like they do on the hondas to get rid or any surges from a ps rack without oil
unless.. anyone has any issues that a fx-gt needs to have ps?
dedicated trackcar also
sam
021-0290-7728
LOWDWN
Postby KinLoud » Wed Mar 18, 2009 11:25 pm
I pretty sure that Motorsport NZ requires a powersteer rack to work, otherwise you must run a non powersteer rack.
If it's a trackday car then it's your decision...
I would do it the right way not the easy way.
Ken
Auck
021 408 863
Postby Mr Revhead » Thu Mar 19, 2009 10:57 am
also why would you want to go to manual steer in a dedicted track car?
Postby gepsk8 » Thu Mar 19, 2009 7:52 pm
yip, get a rack from non p/s ask cambo1 hes done it.
O272754663
gepsk8
Postby TRD Man » Thu Mar 19, 2009 9:17 pm
There is no requirement in Schedule A requiring a power steer rack to remain operative.
In our EP81 rally car we removed the power steer pump & lines but left the original rack with a little fluid inside and a loop between the outlets.
Worked fine like that for years.
Not sure if I'd want to do it to a Corolla circuit car though but each to their own.
TRD Man
Postby LOWDWN » Thu Mar 19, 2009 9:33 pm
cheers for your input,
sam.
021-0290-7728
LOWDWN
Postby crispy'86 » Fri Mar 20, 2009 6:36 am
Mr Revhead wrote:also why would you want to go to manual steer in a dedicted track car?
Have the words "weight reduction" not entered your head Warwick? :lol:
Did that to my fxgt, saved a s(%t load of weight and you don't really have to struggle to turn the wheel,
Get a non-power steer rack and possibly will need column to suit it too, my ae82's had different lengths of steering column between power and non-power steer racks
crispy'86
Postby Mr Revhead » Fri Mar 20, 2009 10:53 am
cant be fun driving a FWD car with max castor and wide slicks with out power steering....
Postby LOWDWN » Fri Mar 20, 2009 6:03 pm
i like your style, i can always change back if my guns arent big enuff to cope :roll:
021-0290-7728
LOWDWN
Postby 85AW20v » Fri Mar 20, 2009 9:39 pm
AW11 rack might fit - it's all manual. If it's too wide it might only be the tierods that need changing to bring the length down.
See ya
Simon
85 MR2 20v
85AW20v
Postby strx7 » Sat Mar 21, 2009 7:49 am
you need, rack, coloum & the shaft with universal joint between the 2 as they have different sized spline between p/s and non
