silvertop ae101 to blacktop ae111 with 6speed
Postby CorollaGTZ3dr » Sun Apr 05, 2009 3:16 pm
i have an ae101 fxgt( engine is F,ed) and i also have a blacktop, loom ecu and 6speed sitting on my garage floor.
will the blacktop and 6speed go straight in and mtach up with all the mounts? and driveshafts?
will the wiring and ecu simply replace the silvertop wiring and ecu?
has anyone completed a similar conversion(silvertop to blactop)
any help or info would be awsome. dont want to find out the hard way that its not goin to work.
Cars Owned(ones worth mentioning)
Ford Escort MK2 2.0L(current)
Mitsi starion turbo
81 Celica 3Tgte
MA70 Supra 7Mgte x2
Sentra SSS
SW20 MR2 Turbo(fastest so far)
GTS4 Skyline Turbo
AE101 corolla 4Agze conversion
CorollaGTZ3dr
Postby TRD_ZERO » Sun Apr 05, 2009 3:39 pm
You dont really want the 6speed box its more money than its worth. try find a c56 lsd box which is stronger.
Previous:
TRD_ZERO
Postby xsspeed » Sun Apr 05, 2009 3:50 pm
you should be able to flog off that 6spd box on trademe for more than enough too. Def get yourself a c56 with lsd instead. 6spd is just wank factor in this case.
bolting up should be sweet. I think wiring can be a mission/can be done?
