adamkerrnz wrote:I will be using the stock rails off my OEM seats and modifying them to bolt the new seats onto.
Mr Revhead wrote:adamkerrnz wrote:I will be using the stock rails off my OEM seats and modifying them to bolt the new seats onto.
that bit also means you need cert
adamkerrnz wrote:I know that in my case i DO need a cert as my car has airbags up front.
1I1 wrote:If your car does not have airbags in the seat, but airbags in your steering wheel/dah your seat base must be a the same height as your OE seat. So if you use approved seat rails/seats no cert is required.
Mr Revhead wrote:note all seat modifications.... surely modifiying rails to fit the seat comes under that.
may depend on the scope of the mod as to wether or not you will get away with it, but by the letter of the law it needs a cert.
however as often is the case in the VIRM, the inspectors opinion is the deciding factor... i bet you can find inspectors who would argue either side.
