4age Blacktop 20v Rebuild Suggestions
Postby rx7guy » Mon Apr 06, 2009 11:46 pm
So it seems like the general consensus is for the acl race bearings, with toyota rings and gaskets. Will price them up sometime soon.
The torque band is wide and the road is narrow
rx7guy
Postby Bling » Tue Apr 07, 2009 12:19 am
Don't forget to check the sponsors section for toyota parts 8)
Postby rollaholic » Tue Apr 07, 2009 4:15 pm
i think it pretty much comes down to who you know.
i just got a bunch of 4age stuff from ACL via repco, they supplied mahle piston rings. i'd be surprised if these were any worse than factory parts, but i guess time will tell.
to the OP, post up prices on what ya get! will be interesting to see how they compare.
oh i also looked at the retail prices for the complete bearing set, and it was about $250 for ACL race BE, mains and thrusts
guess im too used to not paying retail :) can say i paid alot less than what acesniper was suggesting were staff rates at repco :?
Postby escortman » Tue Apr 07, 2009 6:35 pm
yeh i got mahle rings as well had to make 1 set out of 2
4x4 toyota blizzard offroader
escortman
Postby rx7guy » Thu Apr 09, 2009 3:47 pm
Hey got retail prices for acl race bearings at supercheap today, $60 for big ends and $75 for mains. So they are really cheap there.
But they wanted $400 for a top end gasket set. Sweet bargain...
rx7guy
Postby Mr Revhead » Thu Apr 09, 2009 5:34 pm
:lol: just over $100 for genuine! :lol:
Postby Dell'Orto » Thu Apr 09, 2009 6:37 pm
Yeah for some odd reason both ACL and NZG silvertop headsets are stupidly spendy...$110+ I think for the TGP set.
Postby AceSniper » Thu Apr 09, 2009 7:52 pm
Iv been quoted $40 big ends $60 mains +gst
for acl race bearings from BNT ...
AceSniper
Postby rollaholic » Thu Apr 09, 2009 8:08 pm
thats a sweet price for a headset. i didnt get one as i've got a TRD head gasket, so ended up buying a few bits and pieces individually
Postby AceSniper » Sat Apr 11, 2009 7:53 pm
corrected on repco staff
mains 49 bigends 38
AceSniper
updated costs
Postby Logan » Sun Oct 30, 2011 11:48 am
Anyone rebuilt a blacktop recently?
Have a runner, but smokey, and gunked up. After a estimate for;
Labour (Will dissassemble & reassemble myself)
Acid tank, clean all components, check bearing clearance, set valve clearances
Parts
Bearing Set (acl race?)
-mains
-bigends
-thrust
Gasket Set (genuine?)
Ring Set (genuine seams to be the go)
Cambelt
Tensioner
Waterpump
Anything else need for a freshen up?
SR Sold. Onto Other Things
Logan
Postby Grrrrrrr! » Sun Oct 30, 2011 1:27 pm
silvertop con rods if you are going to be going near the track or thrashing it heaps on the road..
Grrrrrrr!
Postby RedMist » Sun Oct 30, 2011 3:05 pm
Although everyone seems to be pressing ACL bearings I haven't had much luck with them. I suspect it's simply because they are a very hard shell and can't handle the slightest lack of oil pressure. I'm having better racing runs with stock.
You may also want to think about forging the internals. USD is extremely good at the moment and the piston manufacturers seem to be having sale battles.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Logan » Sun Oct 30, 2011 6:37 pm
Thanks for comments. Just looking for the cheapest option for a good reliable hp, having previously well thrashed a bt on the track for a few years without an issue I am not scared of using factory rods and am also well satisfied they make enough hp.
Have been somewhat seduced by the dark side of racing on gravel and will be going into a fxgt, and the name of the game is to keep it low cost.
Logan
Postby Leon » Sun Oct 30, 2011 7:00 pm
having a conrod that doesn't exit the side of your block is cheaper :wink:
Postby KinLoud » Sun Oct 30, 2011 8:57 pm
Rods - if your rebuilding the engine I recommend using silvertop rods.
Image Image
Balancing.... factory toyota balancing for crank is pretty good
Marshall Motorsport did my machining and balancing - he was fairly impressed with how good the factory crank was (he balanced 2 for me). Same with the factory flywheels
The rods are matched at the factory so the variation isn't too bad (not as good as crank though).
If you get your rods resized then they will balance them at the same time.
ken
