Flywheel bolt hole oil leak...
Postby Boosted_162 » Sun Apr 12, 2009 6:09 pm
Well, im in the middle of changing the clutch in my RC (what a freaking mission). Got to taking the flywheel off, and oil comes out the flywheel bolt holes (no i didnt drain the oil, i hoped to get away with it :lol:). Now, is this normal? Or does it mean the rear main seal has gone? I dont really want to put my brand new exedy/jun flywheel on to get ruined!
Postby Dell'Orto » Sun Apr 12, 2009 6:11 pm
Out of the flywheel bolt holes? :? as in the holes in the flywheel, or the crank? Do the rear main while its apart, cheap insurance.
Postby Boosted_162 » Sun Apr 12, 2009 6:13 pm
Dell'Orto wrote:Out of the flywheel bolt holes? :? as in the holes in the flywheel, or the crank? Do the rear main while its apart, cheap insurance.
As soon as i loosened the flywheel bolts, oil started dripping out where the flywheel bolts to the crank. As much as i need to get the car going, i think it may be a good idea to do rear main while the motors out..
Postby Dell'Orto » Sun Apr 12, 2009 6:14 pm
Boosted_162 wrote:As soon as i loosened the flywheel bolts, oil started dripping out where the flywheel bolts to the crank.
Do the rear main 8O
Postby Lloyd » Sun Apr 12, 2009 6:16 pm
Shouldn't leak, there is nothing to leak there. The rear main seals between the back plate and the crank, not the flywheel. Should probably do it while you're in there as it is the perfect opportunity though
Postby Boosted_162 » Sun Apr 12, 2009 6:17 pm
Do the rear main 8O
It explains why the whole motor is covered in oil, as well as inside the bellhousing! :lol:
Hopefully TNZ have one in stock!
Re: Flywheel bolt hole oil leak...
Postby Jason T » Sun Apr 12, 2009 6:28 pm
Boosted_162 wrote:Well, im in the middle of changing the clutch in my RC (what a freaking mission). Got to taking the flywheel off, and oil comes out the flywheel bolt holes (no i didnt drain the oil, i hoped to get away with it :lol:). Now, is this normal? Or does it mean the rear main seal has gone? I dont really want to put my brand new exedy/jun flywheel on to get ruined!
Wow...
Flywheel to crank bolt holes will leak oil like all 3S series engines and 99% of Toyota engines will when bolts are removed
No the bolt threads will not leak...if you like use loctite
Crank rear main seal is the orange seal around the outside edge of crank should be changed with clutch kit if any oil is inside bellhousing has no relation to crank / flywheel bolts
Fixing Toyota's since '87
Jason T
Postby Boosted_162 » Sun Apr 12, 2009 6:34 pm
Wow...
Ahh ok, nice to know. Had read conflicting info everywhere. Yeah, definately oil in bellhousing so will replace the main seal before i put it back together.
Postby matt dunn » Sun Apr 12, 2009 11:14 pm
Jason T wrote:Flywheel to crank bolt holes will leak oil like all 3S series engines and 99% of Toyota engines will when bolts are removed
Really,
Not on any I've seen as all the bolts are blind threads into the end of the flywheel, but then I have only done a few different versions.
Postby 85AW20v » Mon Apr 13, 2009 12:10 am
Maybe the last owner got carried away with oiling the bolts prior to torquing the last time it was apart.
See ya
Simon
85 MR2 20v
85AW20v
Postby sergei » Mon Apr 13, 2009 9:55 am
I can confirm with 3S the holes are through.
If you remove bolt it will leak oil out of there.
I had those WTF moments too ;).
