just a guess but I would have though it would be knock sensor related, as if it detects a more than normal amount of knock, and it drops a bit of advance and it's still there, it may drop the boost,
and knock would be worse when th IC is hot????
MAGN1T wrote:Another possibility is an exhaust leak. Cast manifolds can warp and unseal but only when excessively hot. No you won't nessecarily hear it either.
Twolitre wrote:Akane do you run an aftermarket boost controller AND the vsv plumbed in together?
