themaleman wrote:i thinik any 4agze 1 will do, and may need a matching plug. i was told by toyspares that 4age ones are different
strx7 wrote:pretty much any toyota engine can donate the knock sensor to your cause as long as its either a) got the right plug or b) comes with a bit of loom so you can join it.
MAGN1T wrote:They're nothing more than a microphone in a fancy package. If they've only got 2 wires then there's no way they can have anything fancy in them. You can even hook them up to a preamp if needed and have a listen to what's going on over the top of all the electrical noise.
All the fancy electronics are in the ECU.
Steve
BZR4AGE wrote:On a side note, this means that a 20V silvertop knock sensor will work fine on a blacktop and vice versa, because they are of the same plug, bore size etc etc?
MAGN1T wrote:Every telephone uses an electret mic. It's a piezzo crystal with a FET built in. They're also polarity sensitive. If you get the wires the wrong way round it won't work.
They're made by the millions and put into different boxes with different names on them just to confuse the customers into thinking that theirs is "special" and worth a lot more than 50c. People in the trade like to talk a load of shyte.
MAGN1T wrote:All the circuitry, filtering etc is in the ECU. There might be some minor differences in reponse though between knock sensors, maybe do do with the box that it's mounted in.
Think of it another way, a standard off the shelf electret mic has a frequency reponse of 50Hz to 15KHz which covers your hearing range. Knock might be about 5KHz depending on the motor.
The ECU is made up from pretty much off the shelf parts although the microprocessor is a bit custom and there's some custom hybrid circuits in there also made from standard parts. It wouldn't really make sense to use a special, one off microphone to do the job.
Besides when you wire up a knocklink to your car, the instructions say it works with any knock sensor or if your car doesn't have one, you can wire any knock sensor up to it..... it even works with a normal microphone.
How would you ever know that it's not working unless you hit it with a hammer and monitor the output? How does the ECU bring up a fault code when under normal conditions it doesn't put out a signal. Maybe if it's been disconnected or it's gone open circuit and doesn't draw any current ?
