deaf_rattle wrote:oh, for a set, hmm can you do pairs?
That shouldn't be a problem - let me check
xsspeed wrote:Damn thats a sharp price given the exchange rate, or are these wheels already in nz?
toyae86 wrote:what can you do wheel wise for ae86 14 or 15 by 7 or 8
nz_climber wrote:Anything in 15*7 or 15*6.5 with Ford PCD (4*108) or can be redrilled and between zero to 30p offset?
Its for a lotus 7 replica and after something different to superlites
Aaron
dnalunchie wrote:Hey im after some heavy duty/performance brake pads for my rs legacy the car is a street car and I would only be needing front pads, also some dot 5.1 brake fluid too
The car is a 1989 rs legacy sedan also known as a BF5
Thanks
Feel free to txt or ring on 0273925842 or pm or reply in thread
Ben
Fortyone.co.nz wrote:dnalunchie wrote:Hey im after some heavy duty/performance brake pads for my rs legacy the car is a street car and I would only be needing front pads, also some dot 5.1 brake fluid too
Thanks
Ben
Heavy duty as in they can stand up to a thrashing or two, or heavy duty as in they will last longer than the the discs?
Fortyone.co.nz wrote:For the chassis code and age of car, the Japanese price lists are the only ones with options that I can see. Endless does 5 pad applications, all for street (not recommended for race).
Project Mu do an F910 pad in race applications, from $485 / pair
