Adamal wrote:Yea, 13 is a bit high. It MIGHT be alright if you run a thicket head gasket to drop the compression a bit, but you wouldn't be wanting to give it any load at low RPM.
Adamal wrote:I thought that if you drop the compression ratio, then it would decrease the chances of preignition.
Being that when you compress a gas, the byproduct is heat, and this is what causes detonation with a low octane fuel.
doublezero wrote:So maybe a Mahle piston set with a compression of 12.3:1 would work on our pump gas? or do I have to get a set with a compression of 12.0:1?
Gutted that I can't use the TRD ones
Mr.Phreak wrote:Adamal wrote:I plan on making a 10 second car. What would I need to do?
Buy a 20v
Dell'Orto wrote:Yeah 13:1 wouldn't really be feasible on pump gas, maybe if you backed the timing right off but what would be the point?
doublezero wrote:All I was asking was whether the compression ratios would work with our pump gas.
I apologise that a simple question would create such a mocking.
Thanks for all those that answered my question. It is deeply appreciated.
Malcolm wrote:Dell'Orto wrote:Yeah 13:1 wouldn't really be feasible on pump gas, maybe if you backed the timing right off but what would be the point?
Our car runs 12.5:1 with up to 14psi of boost, no intercooler, on pump gas. It's all in the tune (well, a lot of it is).
