Where does the 20v loom bolt to under the inlet manifold?
Postby ChaosAD » Sat May 09, 2009 12:57 pm
Does anyone have a pic showing what part of the engine the loom on a silvertop 20v bolts to where it goes under the inlet manifold?
The bolt holes dont seem to line up with anything.
Thanks
ChaosAD
Postby TRD_ZERO » Sat May 09, 2009 2:11 pm
I might be wrong but doesnt it bolt up to the two support brackets at the back?
Previous:
TRD_ZERO
Postby xsspeed » Sat May 09, 2009 7:39 pm
yeah that plastic bit that runs round the back, bolts to the block/plenum brackets
Postby AceSniper » Sat May 09, 2009 8:12 pm
^^ two studs come off the 2x black brackets that go from the block to throttle bodys
AceSniper
