novice 4agze question
Postby d1 mule » Sat May 09, 2009 5:35 pm
i have recently brought a 4agze for the race car, but im a bit confused as to what version i hav as there is conflicting information on the net....
it is a big port, CAS, Twin coil....
with that information is anyone able to tell me the comp ratio and what its out of????
i have searched the net but as i said conflicting info
cheers :D
d1 mule
Postby Adamal » Sat May 09, 2009 5:37 pm
From memory, the early AFM ones were about 8.7:1 and the later MAP ones (from the AE101's) were 8.9:1
Something like that anyway.
Postby d1 mule » Sat May 09, 2009 5:39 pm
yeah i no the comp changes from 8.0 to 8.9 at some stage. i thought the Dizzy ones were the 8.0 and big port and the CAS ones were 8.9 and smallport.
but mine is bigport CAS which is like in the middle lol
d1 mule
Postby TRD_ZERO » Sat May 09, 2009 5:43 pm
I think there was only two versions bigport and smallport. Smallport being 8.9 and the bigport 8.0. So yours being bigport is 8.0. I could be wrong though.
Previous:
TRD_ZERO
Postby soopachargen » Sat May 09, 2009 5:46 pm
it sounds like its an afm ae92 motor, should have afm, coilpacks, big ports?
When in doubt, down and out.
soopachargen
Postby d1 mule » Sat May 09, 2009 5:49 pm
iv got the entire engine loom up to the computer and there is no AFM or MAP that i can see
d1 mule
Postby soopachargen » Sat May 09, 2009 5:50 pm
then you could have a bit of a problem, i believe the afm wiring is near the water sensors etc,
soopachargen
Postby d1 mule » Sat May 09, 2009 6:01 pm
na the race car has a link and is already wired up for a 4age so im not worried about that just have ro re wire for CAS and twin coil :D
d1 mule
Postby tsoob » Sat May 09, 2009 6:55 pm
afm verfsions are 8.0, later model map sensor are 8.9
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby bluemaumau » Sun May 10, 2009 12:59 pm
4 versions
aw11 dizzy,afm i think 8.0
ae92 early, cas, afm 8.0
ae92 late cas, map 8.9
ae101 cas, map 8.9
feel free to correct me
Postby d1 mule » Sun May 10, 2009 1:35 pm
sweet does anyone have a pic of the plug for the AFM/MAP so i can find it on the loom???
or are the early ae92 bigport and the new ones small port??
thanks guys :D
d1 mule
Postby jakesae101 » Sun May 10, 2009 7:28 pm
not a verry good pic Image
early bigport cas, afm type ae92
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby tsoob » Sun May 10, 2009 9:13 pm
bluemaumau wrote:4 versions
ae101 cas, map 8.9
yup correct
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
