sergei wrote:Don't use locktite on manifold nuts - pointless exercise.
You can locktite head site of the studs, but use proper castle/exhaust nuts, they are not expensive (I also use special wurth washers).
Bazda wrote:Get these washers, they are nicely priced and they seem to work really well.
http://www.nord-lock.com/
cat007 wrote:Bazda wrote:Get these washers, they are nicely priced and they seem to work really well.
Hmm I'll look into them. Are they an off the shelf item in Auckland somewhere? Or will they need to be shipped up from CHCH?
sergei wrote: The locktite is some form of plastic (epoxy or urethane based)
which will fail under temperature.
Crampy wrote:Use locking fasteners or lock wire them up.
That'll stop them from undoing, but you can cut the lock wire in order to remove them when required.
postfach wrote:I'm probably a bit late, but I use Nord-Lock washers and stainless nuts. The washers will stop the nuts from coming loose when you don't want them to, and since the nuts are stainless, they won't really sieze onto the studs so much.
Users browsing this forum: No registered users and 26 guests
