Truenotch wrote:Damn... Both fall on winterseries weekends. Would be so keen to have a go at co driving also.
jakesae101 wrote:definately keen for a ride in levin might be able to help with overalls i have a set of proban coated cotton grey overalls (rnzn issue great for clubsport) would be keeeeeeeeeeen to have a chance to be a co driver
jakesae101 wrote:by the airport could allways courier them to ya then get them off ya at levin
Truenotch wrote:... Provided the Daybreaker goes ahead.
The committee haven't decided whether to do it / not do it / change it in a way that makes it affordable, since there aren't many Rally cars doing much ATM... We had 45 cars last year incl 20 rally extreme, no rally extreme this year and only 10 competing in central regions makes it hard to commit with 40 or less entrants that "might" be there.
Boost_4_Life wrote:jimmeeeeeeehhhhhhh will we be seeing you at the daybreaker then? I'm all go for that this year finally (provided its still on its wheels after preceeding events - touch wood!)
Truenotch wrote:I think they have to pay per KM on forrestry roads normally dont they?
Price wont go up, it will be the same or cheaper. If it runs as a club rally it will be $400 and no notes, which would consist of 1/2 of Stage 6 (Pakihikura) and a mixture of Mcbeth (Stage7), Stage 9, Umutoi (stageand Ridge Rd (stage 10). All based out of Kimbolton, 3 stages before lunch and 3 stages after. Thats the more affordable option at this point (Without using roads twice).
Loudtoy wrote:You will be - i have the same motor just diving the wrong end and without so many flash straight cut bits and pieces. Hopefully i might be able to keep up with you not using notesi hear brendon has pretty much got himself soted only losing his place once on the possum?? YFC ftw on keeping up with things
I see that daybreaker is going to be clubmans level this year?
Return to Palmerston North / Central North Island Region
