Cleaning alternator
Cleaning alternator
Postby iOnic » Thu Jun 04, 2009 7:31 pm
Anyone have any do's/dont's for cleaning an alternator? What should I use to clean it and what should I avoid?
Will degreaser/brake cleaner do any harm? It'll be well dried before it's ever used again but I just want to get all the grease off it before I put it back on the engine
Postby MR2BOY23 » Thu Jun 04, 2009 7:34 pm
On a related note..
I dropped some oil on my alternator while doing an oil change, about a week later it stopped working.
MR2BOY23
Postby gepsk8 » Thu Jun 04, 2009 8:05 pm
don't unless u can know how to strip it down propably and reassembly it
you would have $&#$% ur slip ring and brushes dropping it in oil
O272754663
gepsk8
Postby AceSniper » Thu Jun 04, 2009 10:00 pm
would only use a wire brush to clean housing more than that strip it down... de-greaser could get into the bearings and brake down the grease
AceSniper
Postby kim0663 » Thu Jun 04, 2009 10:03 pm
lol.... i just dunked mine into a bath of degreaser, cleaned the $&#$% out of it,
then sprayed it all out with $%##loads of wd40 and dried for a few weeks, it's back in.
Guess i made a death wish for it so i would be expecting it to die soon....?
Mr2 GT-S
330ci M
kim0663
Postby matt dunn » Thu Jun 04, 2009 10:27 pm
kim0663 wrote:Guess i made a death wish for it so i would be expecting it to die soon....?
Quite possibly.
Postby CelicaGT8 » Thu Jun 04, 2009 10:36 pm
If you just wash it with jiff, scrub it, rince it off with water, let it dry for a few days then it sould be fine, Iv done it a few times, dont see what jiff can do to the brushes.... especialy if you rince and dry it.
Although i have had one catch fire....
CelicaGT8
Postby Dell'Orto » Thu Jun 04, 2009 10:43 pm
If you only want to clean the exterior, take the casings off and clean them, they're not normally too hard to pull to bits.
Postby CelicaGT8 » Thu Jun 04, 2009 10:50 pm
Most people dont no how to, or cant be botherd tho
CelicaGT8
Postby iOnic » Fri Jun 05, 2009 11:14 am
Shit didn't think about that Brad....thanks mate! I'll take the casings off and give them a clean. I only wanna do the exterior so that sounds like the best idea.
