upgrade brake booster
Postby normality78 » Thu Jun 11, 2009 4:19 pm
guy's,
im looking to upgrade my brake booster with master cylinder along. any idea which other toyota family model i can swap over? I was being told celica unit was plug n play
normality78
Postby frost » Thu Jun 11, 2009 4:37 pm
you need to tell us your car buddy.
Postby normality78 » Thu Jun 11, 2009 8:23 pm
ops.... whahaha..... my bad my bad.
Mine was corolla ae111 with 7afe.
normality78
Postby sergei » Thu Jun 11, 2009 8:48 pm
what is wrong with your current brake booster?
Postby normality78 » Thu Jun 11, 2009 9:30 pm
i felt there is not enough pressure to pump my twinpot. I've fix a pair of Superstrut twinpot to my ae111 but the pedal felt very spongy. I've bled the brake hose with fresh dot fluid but doesnt help. I have to depress till certain length only the brake start to bite. Brake pad still sufficient
normality78
Postby fangsport » Thu Jun 11, 2009 10:22 pm
not the booster.
you will need the master cylinder of the donor vehicle.
fangsport
Postby normality78 » Fri Jun 12, 2009 1:22 am
fangsport wrote:not the booster.
you're reffering to this?
normality78
Postby normality78 » Fri Jun 12, 2009 2:31 am
ok. i've carry out the test based on this guide. http://www.autoshop101.com/forms/brake05.pdf
and i failed the test under section "air tightness test under load". My pedal immediately kick back. Also i think i semi-failed the booster operating check. The pedal did depressed but not by little, by alot.
normality78
