by rolla_fxgt » Sun Jun 14, 2009 4:40 pm
I finally had a fine enough day yesterday to do the thermostat & flush, the thermostat change went fine (yup it was the original).
But I couldn't find the bung for the coolant on the bock, so just drained the radiator & did a couple of water cycle flushes, drained it again, and measured out the antifreeze/coolant and distilled water to a 65% ratio, for 5.3 litres that the blacktop manual I found online said. But I only got just over 2 litres of coolant in before it topped out, i ran it for a bit & it went down slightly, so i put a bit of water in, did this a couple of times.
But I'm now worried it will be to much antifreeze/coolant in the engine, and not enough water.
Have I done it wrong?
Can someone point out why it didn't take the 5.3liters of coolant/water the manual said?
Should I worry?
