hilux surf clutch
hilux surf clutch
Postby Nezza » Sun Jun 14, 2009 10:13 pm
I have just put a new clutch master and slave cutch cylinder in my surf. I have bleed the line, the clutch is hard,but when i start the ute, it wont go into gear.
Could i have air in the line, causing the slave not to engage properly?
Nezza
Postby cat007 » Mon Jun 15, 2009 11:18 am
Get someone to look at the slave cylinder and confirm that it is moving when you press the clutch pedal
Postby FLAWLES » Mon Jun 15, 2009 3:36 pm
FLAWLES
