molex wrote:Nobody cares at puke. If your car is able to be driven on the roads without EVERYBODY staring, it's quiet enough. Last time I went I had an empty 2.5 inch pipe off the turbo and you seriously couldn't hear my car in the pits. Had to check it was still idling every so often.
95dba is loud as hell
tsoob wrote:WRONG!! at the last d1 we had 75 complaints in the first hour.
strx7 wrote:all race tracks in NZ are 95 or 96 dba at 30 metres right angle under full load, that means if you are directly behind the car and its under full load, its FRIGGIN loud!!!!
