ST185 issues -- again!
Postby eViLoNe » Mon Jun 15, 2009 6:24 pm
MrOizo wrote:With your almost stalling problem, sounds like the idle up for the PS isnt hooked up right. did you end up taking the PS pump off or swpping it or anything?
PS pump hasn't been touched, ever since the other problems started, that problems been there too. A lot of hissing when when wheel is turned when the ps starts to kick in, so I'd say it's to do with the PS idle.
I'm gunna do the belts, and a ps fluid flush, so when I do the belts, i'll have a look at the idle.
- 1990 Toyota Celica ST184R
- 1996 Nissan Skyline GTS25t
Ex:
- 1990 Toyota Celica ST185
eViLoNe
Postby eViLoNe » Mon Jun 15, 2009 11:20 pm
Hi guys,
Quick (and probably stupid question), where's the ISC located on the ST185? I took a quick look (admittedly, in the dark) for it earlier, and couldn't see it. Any help is appreciated :D.
Ex:
eViLoNe
Postby Boosted_162 » Mon Jun 15, 2009 11:23 pm
eViLoNe wrote:Hi guys,
Underside of the throttle body unit. To get good access you will need to remove the throttle. Its the little white box iirc, and had 2 waterlines going in/out.
Postby eViLoNe » Mon Jun 15, 2009 11:32 pm
Cheers for that. That's tomorrow nights mission, hopefully I can clear out the garage enough, so I can rip it off :lol: :lol:
Ex:
eViLoNe
