MegaStim
MegaStim
Postby johntramp » Thu Feb 15, 2007 2:23 pm
Hey. Does anyone in Chch have a MegaStim I can borrow?
johntramp
Postby B1NZ » Thu Feb 15, 2007 4:55 pm
just out of curiosity what is a megastim?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Ae92typeX » Thu Feb 15, 2007 5:05 pm
megasquirt stimulator... but I dont know what it does lol
edit:
here we are:
The stimulator (aka. stim) is a small board that supplies the signals to MegaSquirt that would normally come from the engine to MegaSquirt, and display the outputs from MegaSquirt on a series of LEDs. This allows you to test MegaSquirt, and learn the tuning software. It also helps you to verify that MegaSquirt is operating correctly if you have problems on the vehicle, and lets you 'play' with MegaSquirt to better understand how it operates. Before assembling your MegaSquirt, you should assemble the stimulator, which you will use to test your MegaSquirt as you proceed.
Ae92typeX
Postby postfach » Thu Feb 15, 2007 5:05 pm
i was going to ask the same thing, instead i looked it up, seems to be a circuit that simulates a running car so you can test your megasquirt without screwing things up on your real car. (correct me if im wrong please, i only skim read)
postfach
Postby Skin » Thu Feb 15, 2007 8:18 pm
haha squirt :lol:
mega squirt even :lol: :lol:
Almost as funny as flange :lol: :lol:
haha flange....
cogent wrote:iPhones can eat a dick.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby slighty_sykotic » Thu Feb 15, 2007 8:51 pm
Ill go dig mine out and send it to you if you promise to send it back :P
And can stand the scary wiring....
(its free form, bascially componats soldered to each other, without a circuit board to hold them).
lol, works great though.
Ill see if I can find it.
--Sykotic
slighty_sykotic
Postby johntramp » Thu Feb 15, 2007 9:14 pm
slighty_sykotic wrote:Ill go dig mine out and send it to you if you promise to send it back :P
--Sykotic
Hey, that would be great.
johntramp
Postby Dell'Orto » Thu Feb 15, 2007 9:54 pm
Surely it would be a simulator rather than stimulator? Seems to me like it pretends the ECU is in a car, rather than makes it horny :lol:
Postby Ae92typeX » Thu Feb 15, 2007 10:02 pm
(stim)not(sim) according to the megasquirt site
Ae92typeX
Postby slighty_sykotic » Thu Feb 15, 2007 10:11 pm
No, its a stim.
Its used during the contructiong phase to simulate certain parts of the circuit. To test (or wake up/stim) parts of it.
slighty_sykotic
Postby spencer » Fri Feb 16, 2007 5:40 pm
I just wired it up, fired up megatune then moved tps, dropped the temp senders in some hot water, blow on the map and your pretty much tested :D injector drivers should be sweet and youll see the rpm signal when you crank it. Unless you hopeless at following insturctions they usually fire up sweet
ms63 crown
spencer
Postby johntramp » Fri Feb 16, 2007 5:51 pm
hey. managed to get it going, turned out to be megatune set up incorrectly. I probably wont need to use the stim anymore slighty_sykotic, but thanks anyway (:
ke70wagon20v, do you have megasquirt controlling spark too? there are a couple of things I am a little unsure of to do with that. if so did you use a second vr input? i am wiring a 20v aswell (I guess that is what you have megasquirted)
johntramp
Postby Loudtoy » Tue Jun 16, 2009 9:40 pm
johntramp wrote:hey. managed to get it going, turned out to be megatune set up incorrectly. I probably wont need to use the stim anymore slighty_sykotic, but thanks anyway (:
Hey i know this is an old thread but wondering if you can remember what version board you were running and if you did your tuning via the serial cable with a usb adaptor or not.
Just trying to get into mine but all i know about it is that it's a v3 board, nothing else as i didn't build it but it was in the car when i brought it. Need to change a couple of settings for the spare outputs around a little
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby johntramp » Tue Jun 16, 2009 11:56 pm
I run a V3 board with a USB to serial adapter.
You should be able to get help on irc.freenode.net #megasquirt if you like.
johntramp
