Howzit people. I've run out of adjustment for camber and toe on my LS400. The annoying thing is the adjuster bolts with the cam washer have a flat-top on the cam. If the top of the cam was rounded off, I'd have more ability to get the alignment in spec.
Does anyone know of a replacement set of camber/toe bolts that might give me the round cam washer i'm after? I assume the bolts dimensions are pretty common through the toyota/lexus range.
Gene
