Engine swap into Hiace
Postby cat007 » Thu Jun 25, 2009 4:26 pm
fangsport wrote:yip.much debate over whether quad-cam multi valve engines should be introduced.
i know of 2.5V6(1vz??) cheap, but not ready for removal from car yet. ordered off the road due to major structural faults.
2VZ is the 2.5L - 1VZ is the 2L
How cheap is cheap? Some sort of camry or something?
Postby fangsport » Thu Jun 25, 2009 5:55 pm
unsure of price. havn't heard it running, but appearantly runs well but leaking oil from either the rocker cover or camseals.is due for cambelt anyway.
fangsport
Postby cat007 » Thu Jun 25, 2009 5:57 pm
fangsport wrote: unsure of price. havn't heard it running, but appearantly runs well but leaking oil from either the rocker cover or camseals.is due for cambelt anyway.
Ah ok. Hopefully the misses wont mind haha.
Are they a good engine normally? Anything normally happen to them?
Postby fangsport » Thu Jun 25, 2009 6:12 pm
do have a bad rep for blowing H/Gaskets, but like turbo toyota diesels, most of it comes down to preventative maintenence.
fangsport
Postby cat007 » Thu Jun 25, 2009 6:22 pm
fangsport wrote:do have a bad rep for blowing H/Gaskets, but like turbo toyota diesels, most of it comes down to preventative maintenence.
hmmm - so might be worth doing the HG on it - as long as I buy if for being cheap enough lol
Postby strx7 » Thu Jun 25, 2009 6:50 pm
the VZ engines actually show signs of a blown head gasket because they crack the oil gallery/water gallery along the top of the block by the frost plugs.
Postby fangsport » Thu Jun 25, 2009 6:51 pm
it's had a new radiator fitted, so it may have already had the gaskets done. trade me is usually well stocked with Camrys with blown trans or H/G. often get a whole car for under $500
fangsport
Postby fangsport » Thu Jun 25, 2009 7:09 pm
strx7 wrote:the VZ engines actually show signs of a blown head gasket because they crack the oil gallery/water gallery along the top of the block by the frost plugs.
ok, so engine in question is rooted??
fangsport
Postby strx7 » Thu Jun 25, 2009 8:49 pm
COULD be, but no gurantees. I think if you dont catch them early enough then the cracked galleries is the result. Have heard of some people just doing headgaskets and they are sweet. To be perfectly honest they are one of the engines i'd just put in the 'to hard' basket
Postby frost » Tue Jun 30, 2009 12:22 am
BZG|Bling wrote:Jealousy works in mysterious ways 8) :lol:
only a joke cos its a 1.6ton ute being slightly pushed by a 1.6 least torque engine he could of found under the toyota badge. a 2t would do a better job of it.
i drive a 20v too
Postby cat007 » Tue Jun 30, 2009 9:08 am
That really how much they weigh? I was thinking about 1400kg
