W58 manual speedo drive options
Postby ke25sr » Tue Jun 30, 2009 3:07 pm
My speed is up the shit reads a lot faster than what i am actually doing.
its different than the other drives i have, its a lot bigger in diameter.
Teeth read 10 & 30. I am sure i want it to spin slower. is there a range of drives?
ke25sr
Postby RomanV » Tue Jun 30, 2009 5:13 pm
Postby ke25sr » Tue Jun 30, 2009 5:34 pm
It does help but now i think i must have missread what was written on the drive.
I thought i had 10 /30
ke25sr
Postby AE25 » Fri Jul 03, 2009 4:20 pm
yes theres a range of drives. what gearbox is this for?
have you tried working out what ratio you require? accounting for tyre size, speedo gauge ratio etc
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby ke25sr » Fri Jul 03, 2009 4:43 pm
AE25 wrote:yes theres a range of drives. what gearbox is this for?
Its a W58 box from a 1995 JZA80, Has a larger speedo drive hole in it than my other W5* boxes have had.
Written on it Is 10 30 and it reads to fast so i am sure i need it to us a larger gear on the speedo drive.
ke25sr
Postby AE25 » Sat Jul 04, 2009 7:56 pm
ke25sr wrote:Its a W58 box from a 1995 JZA80, Has a larger speedo drive hole in it than my other W5* boxes have had.
hmm interesting. ive asked the question on sconz.. might get an answer hopefully. the jza80 speedo drive is electronic tho isnt it?
E2 & E7 fanatic
AE25
Postby ke25sr » Sun Jul 05, 2009 2:37 pm
It was originally. but i found a manual drive that fitted
ke25sr
Postby ryanfels » Sun Jul 05, 2009 9:57 pm
what manuel drive did you use?
ryanfels
Postby ke25sr » Mon Jul 06, 2009 8:56 am
ryanfels wrote:what manuel drive did you use?
Dunno. I think it came from a 4WD, Found it on a mates garage floor.
ke25sr
Postby AE25 » Mon Jul 06, 2009 9:27 am
so it could be from a W5#, G5#, R15# or auto?
what size is the hole? i'll have a dig around see what i can find compatible
E2 & E7 fanatic
AE25
Postby ke25sr » Mon Jul 06, 2009 9:42 am
AE25 wrote:so it could be from a W5#, G5#, R15# or auto?
Yes i am sure theyare all the same with minor changes.
ke25sr
Postby AE25 » Tue Jul 07, 2009 12:57 am
and the hole diameter is...
E2 & E7 fanatic
AE25
Postby ke25sr » Tue Jul 07, 2009 9:11 am
AE25 wrote:and the hole diameter is...
Dont know, its bigger than what is in T50's
Its prob close to 25mm. I will take it out again as soon as i get a chance to confirm,
ke25sr
