Dynamat Xtreme - Sound Deadening
Postby Lurkin » Fri Jul 31, 2009 5:12 pm
+1 for the foam sections.
ae101s come with them factory, tucked down behind the rear passengers interior arm plastic bits, tucked in a cavity there, follow the top of the rear wheel well.
bought a bunch of other stuff from pickapart and they didnt even charge to take a few with me? - guess they are not worth much as scrap.
as I had damaged the plastic bit and had it out - they made a significant difference - I've just left them in there as they weigh bugger all and are worth nothing.
point being you can do it youself, and cheaply - whereas the dynamats more expensive and requires other people to do it = $$ in labour.
but I havent used it so it might be worth the money? ... up to you...
Lurkin
Postby GTCRSHR » Fri Jul 31, 2009 5:38 pm
Roy wrote:point being you can do it youself, and cheaply - whereas the dynamats more expensive and requires other people to do it = $$ in labour.
if you can apply cellotape to a piece of paper, you can apply dynamat
no need to pay any one to do it,
Nothing to see here ...
GTCRSHR
Postby scotty_ish » Fri Jul 31, 2009 7:37 pm
DeeCee wrote:
(watch fingers as the DX is a foil with thick adhesive material/goo on the back - it becomes a serrated knife when you cut.
quoted for truth!!! cuts worse than an emo when you accidently run ya finger along the edge of it when your pressing it onto the surface. its friggen nasty lol
dnalunchie wrote:Sometimes I really love this place..... the other 6 days of the week I think $&#$%....those bitches better not bring up my sister.
scotty_ish
Postby Dopamean » Fri Aug 14, 2009 5:24 pm
Put it this way, I lost half the sound through vibration before I applied the sound dampening material.
This is in my BZT Carib.
I don’t think I could have made a better investment.
Dopamean
dynamat
Postby lowglrolla » Sat Aug 15, 2009 7:24 am
yea works great . i have lots in my gtz trueno . quietens lots and great mid bass in front doors . same in my gfs legacy wagon . and also worked great in front doors of r34 skyline i did. no bulk packs left in stock at supplier current reship due 3rd sep. if u cant find any . i sell it on trademe when in kiwiland
92 gtz trueno
89 gtz levin
lowglrolla
