tsoob wrote:hmm could work, but what about those like me with a 200 item stock list
DeeCee wrote:careful Paulio, you cuold instigate change that affects the status quo...
Dell'Orto wrote:DeeCee wrote:careful Paulio, you cuold instigate change that affects the status quo...
We're always up for suggestions
Paulio - so you mean like having subforums in the FS section for specific bits like TM does?
Adydas wrote:Its a PHP code hack and database hack that would basically run a Shop front within the PHPbb code. Here is one example / demo site of the type of software avalible.
http://www.phpca.net/phpBB2/adverts.php
If this is not the Idea thats been put forward please correct me now as this is what i have taken to understand as being the case.
DeeCee wrote:Dell'Orto wrote:DeeCee wrote:careful Paulio, you cuold instigate change that affects the status quo...
yes i know you are all up for suggestions (and innuendos and other things) but no one seems to act upon said suggestions and there is never a call for comment or opinion on the matters.
Here is a suggestion then: Change the copyright of the site from 2005 to 2009 on the index page.
Adydas wrote:Were actually allready working on this type of an issue, the problem right now is that were limited on access to being able to edit.. well Anything.
DeeCee wrote:Well I know some of this already. It just means someone needs to take the bulls by the horn and sort something out. Tangent anyway.. please continue everyone else.
