AW11 clutch size??
AW11 clutch size??
Postby Knob City » Tue Aug 25, 2009 6:15 pm
found a cheap 4puk clutch from a silvertop, just wondering if it would fit my facelift aw? its 200mm
Knob City
Postby levinguy » Tue Aug 25, 2009 6:36 pm
if you use the silvertop flywheel clutch and pressure plate it will work/fit with the aw11 gearbox
levinguy
Postby Mr Revhead » Tue Aug 25, 2009 7:11 pm
depends what flywheel you have. if you have a 200mm flywheel then no.
i cant remember if/when the late aw11s got the bigger flywheel.... I think they didnt
if your swapping bits, try and get a blacktop flywheel as they are the lightest
Postby mr30%jr » Tue Aug 25, 2009 11:55 pm
theres 2 flys used on aw11 they both use the same clutch size but one has a grove cut around the other is solid.
so no a 212 silvertop clutch would not bolt to a 200 aw11 fly slap a silvertop or blacky on there
mr30%jr
