wheel offset
wheel offset
Postby jakesae101 » Wed Aug 26, 2009 6:47 pm
will +40 offset wheels fit on my ae92 trueno
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby mjrstar » Wed Aug 26, 2009 8:27 pm
deopends on width but if they are around 7'' wide then 40p would be fine.
i guess you'd also need to check centre bore diameter etc..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby jakesae101 » Wed Aug 26, 2009 8:28 pm
there 6 and a 1/2
jakesae101
Postby jakesae101 » Wed Aug 26, 2009 8:31 pm
and they were off ether a ae101 or ae111
jakesae101
Postby tsoob » Thu Aug 27, 2009 10:15 am
what diameter bro? and its 4x100 right?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby xsspeed » Thu Aug 27, 2009 2:11 pm
+40 on 6.5's should be ok
Also depends on tyres, us ethis site to work it out:
http://www.rims-n-tires.com/rt_specs.jsp
Need to know what your current or stock tyres and wheels are, then you can work out what you can fit on
Postby tsoob » Fri Aug 28, 2009 10:12 am
xsspeed wrote:+40 on 6.5's should be ok
site is a bit stupid as it changes the tyre automaticlally you cant try bery many combinations as it just wont allow it.
best tyre size calc i have used is here,
http://www.miata.net/garage/tirecalc.html
However you will need some experience with sizing to get it 100% everytime.
did you sort this problem jake?
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby xsspeed » Fri Aug 28, 2009 12:26 pm
Yeah should have added, does not allow stretch, still, worked well for me
Postby themaleman » Fri Aug 28, 2009 1:25 pm
i have 15x7 (40 offset) rims with 205 tyres on my ae92 no problems. rolled front guards to get rid of the scraping i had when ever id hit a bump in the road. car is slamed 2 on adjustibles
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby ~SlideWays~ » Fri Aug 28, 2009 1:57 pm
themaleman wrote:i have 15x7 (40 offset) rims with 205 tyres on my ae92 no problems. rolled front guards to get rid of the scraping i had when ever id hit a bump in the road. car is slamed 2 on adjustibles
As long as there isn't camber adjustment on the rear it should be sweet.
~SlideWays~
Postby themaleman » Fri Aug 28, 2009 2:24 pm
i cant remember if i have that or not. but i had to use 5mm spacers on each side otherwise the tyres rub on the lowest spring coil
4agte ae92 Levin
a15 powered sj410
themaleman
