Clutch issues
Clutch issues
Postby HELBND » Mon Aug 31, 2009 3:28 pm
before you say it... i'm probably searching as you read this...
Ive got an ae101 with a c56 and im having issues getting it into gear. once youre moving its fine if you play with the revs a bit on down shifts, but it has extreme difficulty getting into gear from a standing start.
if you get it into gear while youre stopped, the car is still trying to move, its like the clutch is not disengaging fully when you push the pedal in. Ive bled the clutch fluid, and got a hell of a lot of air out, but the issue is still there - only with a stiffer clutch pedal :lol:
* Any ideas as to what might be causing this problem?
* and in the mean time, whats the easiest way to get it into first for a hill start? i had a hell of a problem with this 8O
all help much appreciated
Ben
HELBND
Postby tsoob » Mon Aug 31, 2009 4:03 pm
tried bleeding the clutch? split in the fluid line? i had to replace my whole master cylinder and slave cos the rubbers were perished and the slave was seized.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby sergei » Mon Aug 31, 2009 4:11 pm
Bleed again with a mate, it is probably not bled completely, unless there is something seriously wrong with clutch itself.
Postby Paulio » Mon Aug 31, 2009 4:15 pm
Putting it into 1st with the car not running may be easier.
yees booy
Paulio
Postby postfach » Mon Aug 31, 2009 4:19 pm
To me it sounds like there is an air leak somewhere or the clutch is still not bled correctly.
postfach
Postby HELBND » Mon Aug 31, 2009 4:38 pm
ive bled it a couple of times now, with someone else there, it doesnt seem to be getting any more air in it.
I have a new master and slave cylinder arriving tomorrow that hopefully will sort it
HELBND
Postby tsoob » Mon Aug 31, 2009 4:42 pm
postfach wrote:To me it sounds like there is an air leak somewhere or the clutch is still not bled correctly.
thats what i was getting at, i think when u put the parts in that will solve it.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby XS1V » Wed Sep 02, 2009 11:33 am
Have you adjusted the pedal at all?? Can give you more throw (or less throw if it is over engaging) May help ALOT, had to do this in all the skylines at Advanced with aftermarket clutches to get them working just rite :)
Brad
ST205 Group A Rallye #2363
XS1V
Postby Boosted_162 » Wed Sep 02, 2009 7:06 pm
XS1V wrote:Have you adjusted the pedal at all?? Can give you more throw (or less throw if it is over engaging) May help ALOT, had to do this in all the skylines at Advanced with aftermarket clutches to get them working just rite :)
Brad
I did this to get the last bit of life out of the clutch in the RC :lol: :lol:
