dynatron D3800 , avs s5 or mongoose m80g
Postby t0ms » Fri Sep 04, 2009 6:32 pm
Rona73 wrote:also i like their glass break sensors, to me thats te only decent break in sensor you can get because it doesn't pick up false alarms like shock sensors do. if you have a shock sensor and your alarm keeps going off because even the slightest bit of noise from an exhaust sets it off, that means other people like your neighbours etc stop taking interest if they hear your alarm going off.
really? you've never tapped your keys on the glass of a car with a glass break sensor..........
A PROPERLY set up shock sensor is good for deterent. lots of would be theives still do the tyre kick test but it should be set so a decent boot to the tyre will only trigger the pre warn
Rona73 wrote:they have a second button on the remote that can be used for other things
as do 99% of the alarms on the market
mongoose m 60 and m 80
dynatron 3 and 7 series
avs as stated above
even unidens
etc etc etc
i still have a viper 800 from my last car which has 7 available outputs. i used to run window automation (up and down controlled from remote), boot pop, stereo on and flash headlights.... but it was about a 1000 dollar alarm when i got it a few years back[/quote]
t0ms
Postby offensive » Sat Sep 05, 2009 4:30 pm
got an avs in my car
hate it, mostly cause of the remote, likes to unalarm itself in my pocket, or set off the alarm with the other button. lost count of the number of times ive walked back to my car to find it already unlocked
i liked my old viper alarm better on my old car
above this is a line
quote: "Reclusive girls dont shave their pubes"
offensive
Postby Mr.Phreak » Sat Sep 05, 2009 6:28 pm
Is it an older one?? Have found the newer remotes to be better
Mr.Phreak
Postby offensive » Sat Sep 05, 2009 7:40 pm
bout 3 years old
offensive
Postby Emperor » Sat Sep 05, 2009 8:13 pm
I like AutoWatch alarms, had one in my forester, solid as..
Emperor
Postby offensive » Sun Sep 06, 2009 4:16 pm
now my car alarm wont switch off properly. found my door not closed properly which would be the problem, but now it wont arm itself or nething properly. hit a button and alarm goes off, takes alot of button pushes to switch it off again
offensive
Postby offensive » Sun Sep 06, 2009 4:20 pm
car wont start either, go figure! $&#$% useless thing
*edit* i think my battery is dead, stereo wont switch on, dash lights, whatever ones come on look dim. fuel gauge doing strange updown thing
offensive
Postby lucasthefallen » Sun Sep 06, 2009 10:57 pm
have had a mongoose m80g in the caldina now for around 2 years, installed it myself. never had any issues at all.
Need Service or Repair work done? send me a PM
lucasthefallen
Postby XS1V » Mon Sep 07, 2009 9:30 am
offensive - you have PM
Brad
ST205 Group A Rallye #2363
XS1V
Postby Jazza » Mon Sep 07, 2009 11:27 am
Beat this offensive, the day after i got my alarm installed, i had to start sticking my foot on my accelerator to start it, when i found out my TPS, Dizzy, Leads and plugs were all fubar, it made mee feel better though
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
