surface rust treatment
Postby flygt4 » Wed Sep 09, 2009 9:06 pm
I'm picking up a new ute this weekend but I know it has a couple of things I need to sort out. first item is the chassis rails have a light coating of surface rust , and is just starting to flake . Its been on a hoist and its appears to be just on the surface, I'm guessing its from rocks and gravel etc so I just need to clean it up well enough to get a couple of years out of it.
here what I had in mind, please correct/confirm if I'm on the right track.
-strip affected areas with wire wheel, clean and sand
-coat rails in POR15 rust preventive paint
-coat rails in POR15 chassiscote
have I missed anything?
flygt4
Postby Leon » Wed Sep 09, 2009 9:21 pm
buy banjo
Postby Mr Revhead » Wed Sep 09, 2009 9:50 pm
and fluffy dice
yeah POR15 is good, use the metal ready and rust kill stuff first it the situation needs it
Postby B1NZ » Wed Sep 09, 2009 9:56 pm
You could just wire brush/wheel off the worst parts of rust and then buy some hammerite or similar paint, paints straight over rust and is self priming, anywhere between $30-$50 a can from Bunnings/mitre 10 etc....
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby flygt4 » Wed Sep 09, 2009 10:04 pm
hoping to fit token gun rack and dog cages soon after pickup :lol:
ahh yep metal ready i was missing. I'm just gonna hammer it so it doesnt reappear and raise any wof eyebrows. passed a VTNZ wof a couple of weeks ago though.
I think it would be a waste to pull the clutch without celebrating with a suitable burnout first too.
flygt4
Postby Adoom » Wed Sep 09, 2009 10:28 pm
Pump a shitload of fisholene inside the rails after the por15 is dry. Just to get any bits you missed.
Using a paraffin gun on a compressor filled with fisholene is the way to go. Got to be better than buying five thousand fisholene aerosol cans!!!
Adoom
Postby Bling » Wed Sep 09, 2009 11:02 pm
I would just use POR15, its best to topcoat it if its going to be in the sun all the time, but for under a car I wouldn't bother top coating. The sun doesn't actually affect the paints performance, only looks, goes slightly milky. Though I painted the floor in my starlet with it and due to it not being in sunlight all the time it never looked anything but new. 8)
As well as Adooms advice
