lowering kp60 starlet
Postby bacon » Thu Sep 17, 2009 10:09 pm
Whats the best way to lower a starlet?? REAL LOW
bacon
Postby Mr Revhead » Thu Sep 17, 2009 10:13 pm
coilovers, adjustable top hats, roll centre spacers, four link and watts linkage
Postby tsoob » Thu Sep 17, 2009 11:49 pm
Mr Revhead wrote:coilovers, adjustable top hats, roll centre spacers, four link and watts linkage
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Alex B » Thu Sep 17, 2009 11:57 pm
Well, he asked the best way, not the cheapest.
Postby d1 mule » Fri Sep 18, 2009 8:02 pm
agree with revvy, but seeing as you will be gorring all the welding work done on the dif u may as well put a T , F or G series diff in just for shits and giggles, RCA arent a must but def worth while, ana watts linkage is pretty extreme ($&#$% sweet)maybe just a panhard?? bearing in mind i dont no the rear layout of a p60 that well
d1 mule
Postby Dell'Orto » Fri Sep 18, 2009 8:08 pm
Getting KP's real low is tricky, cause of the way their trailing arms angle in toward the diff, makes them bind up.
Postby QikStarlie » Fri Sep 18, 2009 10:09 pm
hmm, never had any binding issues. you have to release the 4 link bolts and do them back up ride height though (stock bushes). else you're basically trying to rip the center out of the bush. which is probably mistaken for binding.
you'l have to chop the bump stops down alot in the rear whatever you do.
QikStarlie
