escortman wrote:The other option (which I prefer) is to use the existing diesel RPM sensor, and swap out the tachometer and A/C computer for the factory diesel ones. This option is easier to install, the tachometer will have the redline in the right place, and it's cheaper -- especially if your truck has only a tach and no A/C, or vice versa. The downside is that the diesel tach and A/C computer will have to come from overseas. If you decide to go this route, find the two blue wires coming from the same connector as the fuel cut solenoid. The solid blue wire gets connected to ground, and the blue/white wire goes to the RPM signal wire
found that from this site http://vpizza.org/~jmeehan/toyotadiesel/ , will have to check it
fangsport wrote:
the above only relates to an injector pump with those outputs.
many early L injector pumps either don't have the RPM output or A/C idle up.
early NZ new 2wd utes often have neither.
