Toyota Primaries
Toyota Primaries
Postby Lurkin » Wed Sep 23, 2009 2:03 pm
was swapping my silvertop extractors for a set of blacktop ones last night..
the three 'bolt's that hold them on are weirding me out? they have (i think) torx heads that screw into the primaries, then have nuts that go over them to hold on the 2 -1 pipe?
any ideas of the purpose of this? why not just use hex bolts like everything else?
Lurkin
Postby gasman » Wed Sep 23, 2009 2:05 pm
i think yhat you might find that its a 12 sided head so you can use the 12 sided socket for extra torque since those bolts are generaly quite hard to get off.
"What can possibly go wrong?"
gasman
Postby nz_climber » Wed Sep 23, 2009 8:47 pm
its just a normal stud and nut situation, the star/torx section on the end of the stud is so you can install and remove them a bit easier..
nz_climber
Postby Lurkin » Sat Sep 26, 2009 11:43 pm
Actually its abit more than that - figured this out through trial and error tonight..
Testing 14mm bolts (toyota) with a new set of extractors proved to be a bad idea.. 2/3 snapped on the undo stage...
therefore perhaps the torx head/ stud + nut is better/ less likely to snap?
either way its gutting to figure it out the hard way!
Lurkin
Postby 85AW20v » Sun Sep 27, 2009 10:33 pm
Can you confirm that the flange pattern from ST to BT is the same so no need to change anything further?
See ya
Simon
85 MR2 20v
85AW20v
Postby thegreatestben » Sun Sep 27, 2009 11:04 pm
Same part number for exhaust manifold gasket
thegreatestben
Postby Lurkin » Mon Sep 28, 2009 10:33 am
Bolts up fine
I used the same metal gasket (ST) as the BT extractors did not come with a gasket (guy posted them to me without one) - therefore had nothing to compare it too....
But nothing needed alteration - just bolted them on in the same place :lol: Easy! :P
Lurkin
