jakesae101 wrote:how much boost are the factory 365s good for?
XSVWGN wrote:jakesae101 wrote:how much boost are the factory 365s good for?
i was running 18psi in my wagon with no problems at all
d1 mule wrote:was told by walter at NZEFI to run no bigger than 450cc on a g1 link as they dont control injectors that well, hence iv got 450cc VR4 jobs which with the right setup are good for 300RWKW+ plus according to Walter, ill post a dyno sheet up as the car is getting tuned on wed
mjrstar wrote:d1 mule wrote:was told by walter at NZEFI to run no bigger than 450cc on a g1 link as they dont control injectors that well, hence iv got 450cc VR4 jobs which with the right setup are good for 300RWKW+ plus according to Walter, ill post a dyno sheet up as the car is getting tuned on wed
I'd like to see 300kw on 450's.. It could be possible if you had 8 of them I spose... or a wet nos system, that might just about do it.
