crank Trigger wheels
Postby ke25sr » Tue Sep 29, 2009 11:21 am
Can anyone here make or supply a 24 tooth crank trigger wheel and a sensor to suit.
I have a really stupid crazy fault that makes no sense, basically my ecu cant work out what one of the 4 teeth is TDC #1 so its making it real hard to start. as soon as its running its fine.
I reckon a 24 tooth trigger wheel missing a tooth will solve this and would like to know if anyone here can supply something
Thanks Y-all
ke25sr
Postby ChaosAD » Tue Sep 29, 2009 12:11 pm
http://www.linkecu.com/products/InstallationAccessories/Sensors/triggerwheel
http://www.electromotive-inc.com/products/mag_sensors.html
http://trigger-wheels.com/store/
What ecu are you running? if its dizzy ignition then it shouldnt matter which tooth is tdc. otherwise you could probably remove 2 or three of the 4 teeth
ChaosAD
Postby nz_climber » Tue Sep 29, 2009 12:24 pm
The Toyota Altezza Beams 3sge engine use something similar to what you are after, here is a picture of it, its mounted to the crank pulley, and sensor just bolts underneath it (think it might be 36 teeth thou)..
nz_climber
Postby ke25sr » Tue Sep 29, 2009 12:35 pm
ChaosAD wrote:http://www.linkecu.com/products/InstallationAccessories/Sensors/triggerwheel
Its a Link G3, I know it shouldnt do it, it doesnt make sense, but going to a trigger wheel is going to be better anyway
ke25sr
Postby mr30%jr » Tue Sep 29, 2009 12:42 pm
using wasted spark?
your dizzy only has one pick up? i know 4a have a 24 or whateva and you just cut one out realitive to no1 on the 4 spike pick up
mr30%jr
Postby ke25sr » Tue Sep 29, 2009 12:45 pm
mr30%jr wrote:using wasted spark?
not sure if he wired it wasted spark. Should ask
Yeah i been trying to get my hands on one to try but not keen on spending a lot on a part i plan to pull apart cut up and possibly find i cant make work
Also have a engineer seeing if he can make me a new trigger wheel for inside the dizzy.
I am exploring all options
ke25sr
Postby ChaosAD » Tue Sep 29, 2009 5:12 pm
Or remove two opposing teeth from the 24 tooth NE wheel and remove the G teeth and sensors
ChaosAD
Postby Lloyd » Tue Sep 29, 2009 5:51 pm
Silvertop dizzy still here...
Postby ke25sr » Tue Sep 29, 2009 6:46 pm
Lloyd wrote:Silvertop dizzy still here...
i got given a damaged one on saturday found it wouldnt work to easily
I buoght a trigger wheel and sensor from Link,
ke25sr
Postby mjrstar » Tue Sep 29, 2009 8:20 pm
the 1g has 2 'wheels' in the CAS one give the rpm signal and the other is dedicated to giving the #1 tdc signal, seems to work well on my link plus.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
