Bazda wrote:Look at Brendons setup on his 4agte. Thats what you need.
taped into the ends of both rocket covers, welded in a splash plate, welded on 2x -10 AN fittings. Into a big 2L catch can with baffles and some steel wool stuffing under neath the breather filters.
He also did a drain back to the sump, that part is up to you if you want to have that option or not.
cat007 wrote:Bazda wrote:Look at Brendons setup on his 4agte. Thats what you need.
As long as the steel wool doesn't come apart of leave any shards in the oil
and you've probably got more problems if you're having to drain your catch can back into the sump.....
cat007 wrote:The water was because one on the by products of burning fuel and the combustion process is water lol
l1ttle_d3vil wrote:cat007 wrote:Bazda wrote:Look at Brendons setup on his 4agte. Thats what you need.
Last time I emptied my catch can it was full of dirty brown water... no oil at all. must've been condensation or something, oil in the engine is fine but I definitely wouldn't want that draining back into the sump
~SlideWays~ wrote:The reason my 4agte has a drain from catch can to the sump is because 16v 4age's have a problem where the oil pump pushes too much oil into the head so it doesn't drain back into the sump fast enough. This is why Mr Toyota added an external oil drain from the head on the last gen 16v 4age (redtop smallport).
So when the head gets too full of oil during sustained high revs, it starts pushing out the breather and into the catch can, hence the reason for a drain back into the sump. I change the oil frequently so there isn't any problems with contamination.
20v's don't have this problem because of the revised head (not just some more valves!).
Happened on my NA bigport 4age, on my bigport 4agze turbo, on my smallport 4agze and happens on my current smallport 4agze turbo. But doesn't on our 20v.
Only happens with sustained periods of high revs, such as a couple of laps at a race track or a spirited drive (on closed private roads).
My setup is a 2L catch tank, with two 22mm outlet breathers directly coming from a sectioned off part filled with steelwool and drainage/breathing holes. The section with the breathers is a removable lid so I can replace the wool. At the bottom of the catch tank there is a 18mm drain hole going into the sump. The cam covers had 24mm holes drilled into the top, a baffle put over the hole and then sealed off with raised alloy boxes on each cam cover, at the highest point of the raised sections it has 18mm outlets which lead to the catch tank.
Check my GTZ project thread for some pics, can take more detailed ones if needed.
tsoob wrote:~SlideWays~ wrote:The reason my 4agte has a drain from catch can to the sump is because 16v 4age's have a problem where the oil pump pushes too much oil into the head so it doesn't drain back into the sump fast enough. This is why Mr Toyota added an external oil drain from the head on the last gen 16v 4age (redtop smallport).
yeah thats what i think ill need to do,
is it possible to setup the external oil drain on my one (its early 8.0:1 AFM version)
cat007 wrote:700ml of water is a shirt load lol
I would've thought you'd get about 100ml MAX every 3-5000km's
Not saying 700ml is bad - as I'm just guessing, but just seems like a lot
~SlideWays~ wrote:tsoob wrote:~SlideWays~ wrote:The reason my 4agte has a drain from catch can to the sump is because 16v 4age's have a problem where the oil pump pushes too much oil into the head so it doesn't drain back into the sump fast enough. This is why Mr Toyota added an external oil drain from the head on the last gen 16v 4age (redtop smallport).
8:0 would be bigport so no oildrain fitting in head or block but you could tap the cam cover and take it straight to the sump.
tsoob wrote:
like out of the rocker cover? striaght back to the sump?
