IH8TEC wrote:mine runs 25-30psi at idle, 10 seems really low, but i think some supra engines are at around 4-5psi at idle,
don't need much at idle as there is no load or anything on it. but up high you'd want 50+ i'd say.
IH8TEC wrote:
matt - now you mention it, when i've seen my oil REALLY hot, as in 125ish deg, it's been down to about 10-15psi on idle. only happened on dyno.
are you checking oil level at engine stop, or at idle??d1 mule wrote:yeah its got a redline mechanical oil pressure gauge, and i have installed a remote oil cooler/filter kit which might have some affect
MAGN1T wrote:If the oil pressure fluctuates with load, it's a sign of a broken piston because crankcase pressure will also be fluctuating with load. An oil pressure gauge doesn't read oil pressure, it actually reads oil pressure plus crankcase pressure, which should of course be zero.
Steve
