96 Levin Airbag
Postby astrae » Wed Oct 07, 2009 10:07 pm
BZG|Bling wrote:Maybe the rules changed from slip on being ok to not ok now?
The landtransport rule is dated 2001 & the cert rule is the same as when I read it in 2006.
Tsoob, if you sell these in your shop you might want to check on this law?
Doesn't matter to me anymore, sold the car to a school girl in march.
astrae
Postby Py7h0n » Fri Oct 09, 2009 8:26 am
Slip on spacers are allowed if you have studs long enough.
2.4(4) A wheel stud or bolt attaching a wheel to a low volume vehicle must engage into or through the corresponding nut or huhb assembly by either:
(a) not less than the diameter of the stud thread; or
(b) a specified number of full turns of thread engagement, which must be not less than:
(i) in the case of a 12mm metric stud or bolt with a 1.5mm coarse thread pitch, 6.5 turns; or
(ii) in the case of a 12mm metric stud or bolt with a 1.25mm coarse thread pitch, 7.5 turns
Py7h0n
