Auto dying when put in gear
Postby .:O4AGTZ:. » Fri Oct 09, 2009 9:51 pm
Its actually an automatic mazda lantis but i figured someone might have some idea. Was driving it today and it died. Turned out that you can start the car fine, but as soon as you put it into a moving gear such as Drive or Reverse the car dies. It was quite a bit jerky when changing gears for a little while as well. Any ideas what the problem could be?
Cheers guys
.:O4AGTZ:.
Postby THA SHZ » Fri Oct 09, 2009 10:53 pm
check that there is no airleaks , like if the plastic piping from the intake to the airbox , that is quite common with those mazdas 8) causes the symptoms you talk of .
THA SHZ
Postby .:O4AGTZ:. » Fri Oct 09, 2009 11:02 pm
thanks! will have a look in6 months time when the rain stops...
any other ideas if this fails?
.:O4AGTZ:.
Postby .:O4AGTZ:. » Sun Oct 11, 2009 12:47 pm
I have also heard that the converter could be locked is that correct? presumably as some solenoid has burnt out. why would it do this? gearbox in need of a decent flush and service i would presume?
.:O4AGTZ:.
Postby loceda » Sun Oct 11, 2009 2:06 pm
sounds like its not coming out of lock up which could be a torque converter, solenoid or ecu problem
suspension travel is an optional extra
loceda
Postby THA SHZ » Mon Oct 12, 2009 9:05 am
also have you checked the atf fluid level yet ?
THA SHZ
Postby YeMs » Mon Oct 12, 2009 12:30 pm
THA SHZ wrote:check that there is no airleaks , like if the plastic piping from the intake to the airbox , that is quite common with those mazdas 8) causes the symptoms you talk of .
i would almost put money on it being this. i have replaced dozens upon dozens of those plastic intake hoses. due to the nature of the rubber it sort of seals when its sitting in place, but when u put the car in gear the motor rocks forward and flex's the hose opening up the hole and letting un-metred air in causing it to stall. just open the bonnet and give it a squeez, if you can see it cracking or perished then that will be your issue.
Your local Hybrid Elite tech
YeMs
Postby .:O4AGTZ:. » Mon Oct 12, 2009 10:16 pm
but when you put it in gear you dont even get the small jerk when you put it in anymore. oh and it is one of the 2L v6 ones btw
.:O4AGTZ:.
Postby YeMs » Tue Oct 13, 2009 12:33 pm
did u check the hose?
YeMs
Postby .:O4AGTZ:. » Sat Oct 24, 2009 1:40 pm
problem found. have put it down to valve body. better be one at pik a part! anyone know a price just while i am here?
.:O4AGTZ:.
