Loudtoy wrote:So apparently 1 and 2 might actually do something but possibly not, to figure out if it's worth while doing you nedd to 1st buy a gauge and put it somewhere you can see it.
Andto all you people who have ever said the best gains over standard would be to put an aftermarket filter in the factory airbox.
pc wrote:I think dyno testing would be more scientific... more expensive yes, but the goal isn't to reduce the negative air pressure in the intake, it's to get more torque/power... so why measure air pressure?
Did they prove in previous testing that varience in air pressure in the intake & torque over the entire rev range on dyno results correlate exactly?
Adamal wrote:This thread is worthless without a RomanV trademark graph.
Affroman wrote:On Sunday the local FPV/Tickford club had a dyno day. Very interesting as on 4 models AU Fairmont straight 6, V8, T3 TS50, and a BA XR8 preformed a comparison of "with airbox" and "without airbox" dyno runs.
ALL had an improvement. THey were
AU Fairmont 4.0L VCT single cam 6, 134kW to 137kW
AU Fairmont, 5.0LWinsor V8, 143kW to 154kW
FTE T3 TS50, 5.6L stroked Winsor V8, 162kW to 173kW
BA XR8, 5.4L BOSS V8, 230kw to 244kW
The BOSS didnt get a bottom end torque increase as the others did but benifited most at the top end as the twin cam head breathed much deeper than the others.
Apon investigation it was found that the air entry into ALL airboxes were not up to the task of suppying air for the engine. The holes for the airbox were smaller than the main induction pipe to the plenum and had nasty bends and kinks not helping airflow at all. The air cleaners themselves where in good condition, yet probably didnt help the situation either.
When designing an airbox, be sure that it isnt being a restriction and you will be rewared with induction noise, exta power/torque and fuel economy.
