I tried to find information regarding battery mounting, but didnt have much luck.
Are there any guidelines available?
Mr Revhead wrote:Might want to ask FPR about mounting batteries near fuel systems![]()
Adoom wrote:Mr Revhead wrote:Might want to ask FPR about mounting batteries near fuel systems![]()
Que? My Fuel Pressure Regulator does not talk..... Does yours?
Loudtoy wrote:Adoom wrote:Mr Revhead wrote:Might want to ask FPR about mounting batteries near fuel systems![]()
LOL talking fuel pressure regulator.
FPR - Ford Perfomance Racing
Another question how is that insulated from between the plate and the terminal - looks to be pretty close and not any form of insulation that i can see in that picture.
Plus don't think you actually need seperate bolts for the box and the battery, if you break the battery mount bolts chances are you've had that much of a shunt that the box is just going to split around the bolts or if it's a plastic jobbie the plastic will just break apart anyhow, then you end up with fpr's scenario
RomanV wrote:I've heard a few people previously confuse MSNZ regulations with WOF regulations, you dont need to have the battery vented, or many of those other things if the battery is in the cabin of a road car for wof/cert.
Which is not to say it's not good practice to 'future proof' any work you do incase it has to conform to those regulations later, as well as doing it as safely as possible...
But it isnt required.
Best way to find out what's gonna be okay, ring up the cert guy who's going to be looking over your car.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
