Random flat spot?
Random flat spot?
Postby cat007 » Sat Oct 17, 2009 5:04 pm
Hi all
Noticed today, and possibly yesterday, but today it's really bad.
There's a shudder, almost like a really out of balance wheel.
I cant see any missing weights
I did notice however, that when slowing down, you can feel what appears to be a flat spot.
Either a flat spot or the wheel is no longer round
I've not locked the brakes so cant see how it could be a flat spot. Can wheels become oval if they are old, or maybe taken past their max speed etc?
Hunt
Postby Crampy » Sat Oct 17, 2009 5:13 pm
Chuck it on a balancer, that should reveal all.
Crampy
Postby tsoob » Sat Oct 17, 2009 5:50 pm
flat spot on the tyre? handbrakies at all bro?
bring it down if u like will spin it up
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby MrOizo » Sat Oct 17, 2009 5:52 pm
If it has been sitting in one spot for a while it could result in a flat spot.
Main reason the yanks put their cars on stands during the winters.
MrOizo
Toyspeed Legend
Postby Adoom » Sat Oct 17, 2009 6:39 pm
Is one of your brake rotors warped or cracked maybe?
Adoom
Postby Loudtoy » Sat Oct 17, 2009 7:39 pm
Could be that you just have a bulge in one of your tires, that will make it feel like that as well
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby cat007 » Sun Oct 18, 2009 2:29 pm
tsoob wrote:flat spot on the tyre? handbrakies at all bro?
haha nah - no handbrakies - too hard with a 'twist and release' handbrake :P
I'll see if I can take a long lunch one day and shoot over the bridge for a visit :)
Postby cat007 » Sun Oct 18, 2009 2:30 pm
Loudtoy wrote:Could be that you just have a bulge in one of your tires, that will make it feel like that as well
Yeah could be - Might take the tyres off either tonight or tomorrow night and see if I can visually see any disformations'
Postby 79rolla » Sun Oct 18, 2009 6:27 pm
also check you don't have a buildup if dirt ect on the inside of the rim, that can put a wheel out of balance by quite alot..
also as tiers wear the balancing can be affected depending on the imperfections/defects in the tier (is worse on cheaper tiers)
past: AE82 FXGT
79rolla
Postby cat007 » Sun Oct 18, 2009 7:04 pm
79rolla wrote:also check you don't have a buildup if dirt ect on the inside of the rim, that can put a wheel out of balance by quite alot..
Good point - I'll take a hose to the rims
79rolla wrote:also as tiers wear the balancing can be affected depending on the imperfections/defects in the tier (is worse on cheaper tiers)
Seems strange that it happened overnight though....
Postby 79rolla » Sun Oct 18, 2009 10:11 pm
if it is dirt then youl need to take to them with a scraper of some form, a hose wont do much lol
to check for out of round/buldges you can just jack it up and spin the wheel and watch it compered to one spit on the inner guard, the surface should stay in the same place, if it moves a bit youv got a problem, if you get what i mean
if none of that works take it off for a look and you may need to take it for a balance.
also it could be a wheel alignment issue if none of that works
prosses of elimination :wink:
past: AE82 FXGT
79rolla
Postby cat007 » Tue Oct 20, 2009 3:08 pm
Well I didn't take the wheels off but found what appears to be a bulge about 4 inches long running around the inside of the tyre.
The tyres have heaps of tread but must be old as they're all cracked around the base of the tread.
Bit of a shame as I cant afford new tyres right now. Maybe I'll just chuck my supra rims on :D
Postby Bazda » Tue Oct 20, 2009 4:34 pm
Did you manage to put on the bigger brakes?
Postby cat007 » Wed Oct 21, 2009 3:00 pm
Bazda wrote:Did you manage to put on the bigger brakes?
The ali is cut and ready to be picked up, (probably tomorrow now) then this weekend I'll drill and tap the holes. Then put em all on wahoo :)
Postby cat007 » Fri Oct 23, 2009 8:55 am
Well the tyre burst last night so no need to get it balanced haha
Have got spare on but will need a replacement
Nick if you're reading this - do you have, or can you get some of those light truck tyres like what I bought off you last time? I can't remember the size - can you? haha
Postby Mr Revhead » Fri Oct 23, 2009 9:15 am
you found that bulge and kept driving on it??
Postby tsoob » Fri Oct 23, 2009 9:27 am
cat007 wrote:Well the tyre burst last night so no need to get it balanced haha
yeah man i can get it you just need 1? or want to do the pair.
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby cat007 » Fri Oct 23, 2009 9:45 am
Nick
Just 1 for now. The other seems to be fine
Postby tsoob » Fri Oct 23, 2009 5:18 pm
cat007 wrote:
Nick
ok its here now bro will be open tomorrow 930-12
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
