petrol surf
petrol surf
Postby rollaholic » Mon Oct 19, 2009 7:22 am
the missus dad is looking at getting himself another surf after losing his work one, and hes got a couple of v6 ones on his watch list - the 93-96 kinda era... is this the infamous blown headgasket 6 found in the camrys? (1VZ-FE?)
i've seen a few of this shape get rust in the doors, any other common faults to watch out for?
any info appreciated!
Postby Mr Revhead » Mon Oct 19, 2009 8:46 am
Yes they are the ones famous for BHG. And usually it's buggered heads that cause it. So you can always just replace the gaskets.
where magn1t? he will actually be right in this case.... :lol:
And to compound the issue, all the electrics in the V go brittle with the ehat and can fall apart when touched.
Other than that they are a surf, so no real issues.
So buy one, then slip in a 1uz 8)
Postby rollaholic » Mon Oct 19, 2009 12:31 pm
i presume you mean you CANT always just replace the gaskets.
not that i would want to anyway, bleh
1uz is a nice idea, im sure he would be keen but his wife probably not so much haha :D
Postby Mr Revhead » Mon Oct 19, 2009 12:35 pm
:P yeah thats what i mean
why not? will be cheaper to run than the V6!
find a cheap one with dead engine and away you go
Postby Quint » Mon Oct 19, 2009 4:21 pm
Get one with a 3L, end of troubles.
Quint
Postby andyztouring » Mon Oct 19, 2009 6:08 pm
Avoid the V6(3VZ-## series engine),as mentioned above they blow head gaskets often caused by corrosion on the top of the block (ask any engine reconditioner) and they drink petrol big time when are are running. Rust in front doors and top of rear door(side door) openings.Check for play in steering idler -cheap to replace if worn, also on a V6 check for noisy cambelt idler,but replacement idlers are only $39.88 at Toyota.But dont buy a 3 litre V6!!!!!
andyztouring
Postby fangsport » Mon Oct 19, 2009 7:29 pm
Quint wrote:Get one with a 5L-E, end of troubles.
corrected.
fangsport
Postby thegreatestben » Mon Oct 19, 2009 7:32 pm
Drove a 2.7L petrol one recently.
Seemed nice, wasn't slow as I was expecting but you would probably not want to tow with it.
Avoid v6's. I like KZN models the best, except for doing oil drain/feeds on them :evil:
thegreatestben
Postby strx7 » Tue Oct 20, 2009 7:01 am
the rzn185's are an ok vehicle, not over induldged with power but it all depends what you are after, obviously a intercooler kzn185 would be the pick of the bunch but they are still fetching close to $15K.
185 series over the 130 series everyday
Postby rollaholic » Tue Oct 20, 2009 5:34 pm
yeah im keen to get him into a KZ powered model, hes come from a late model lux with the turbo diesel (forget the engine code on the new ones) so an atmo diesel is gonna be pretty disappointing for him.
im well aware of the shortcomings of the VZ, just was not 100% sure if it was what they put into the surfs.
cheers for feedback folks
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
