Crampy wrote:http://www.blackclouddiesel.com/FORD/TAG/tag.htm
Are these for real or what? Is it really going to do that much to the intake? I have heard of people using honeycomb sections in their intakes, to help direct air properly over the MAF sensor element. I believe Altezzas suffer when putting pod filters on them, making them run a bit rough due to disrupted air flow through the MAF.
steve murch wrote:fivebob wrote:Which section flows better, round, oval, square, or rectangular
depends on design,angles,volume,engine flow,cam,rpm etc etc
fivebob wrote:steve murch wrote:fivebob wrote:Which section flows better, round, oval, square, or rectangular
Yes, but if you optimised each section type for the same engine which one would give the greatest flow, or would there be no difference?
Crampy wrote:Is it best to have a super smooth surface of the inside of the pipe, or a slightly rougher surface?
fivebob wrote:Crampy wrote:Is it best to have a super smooth surface of the inside of the pipe, or a slightly rougher surface?
In theory it depends on what sort of flow your have in the pipes, Laminar flow has less drag, but is prone to separation which greatly increases drag, turbulent flow has more drag but is less prone to separation.
In practical terms it probably doesn't matter a great deal as the layer of air that is actually in contact with the pipe walls is not moving anyway. Polishing things to a mirror finish won't give you any noticable performance improvement, though it's generally accepted that a rough surface is better after the point that fuel enters the system to promote mixing.
