ee904age wrote:It cranks good but only fires once then just turns over and over. My thinking is I've c*cked up the cam timing and its firing at the top of the exhaust stroke.
Mr Revhead wrote:have you triple checked all plugs etc? hooked up the earth? Wouldn't be the first time someoen forgot to put the earth back on!
ee904age wrote: Would doing this be any different to taking off the belt, turning the crank 360 deg and reinstalling?
It's gotta be better than the other way thats been suggested, of swapping the leads over on the cap (ie: 1-3 and 4-2)!
fivebob wrote:Rotating the crank 360° will achieve nothing
strx7 wrote:i'm assuming its got an air flow meter right? is it plugged in? is it getting consistant fuel pressure?????
ee904age wrote:Theres plenty of fuel getting to the rail and theres definately spark on all four. When Disconnecting coil and cranking then pulling the plugs they're dry with no smell of fuel.
Any ideas people? Other than faulty injectors?
Ive checked for codes and theres nothing.
ee904age wrote:It Runs!! By bridging terminals FP & B+ it goes. I'm assuming this points to the AFM not sending a signal and therefor cutting fuel after cranking. The AFM is plugged in, but I notice the plug on the AFM itself has about 8 pins (ish) and the plug on the loom only has four. Do I have the wrong AFM or is it that they use the same AFM for a few different models?
85AW20v: How do I check the AFM earth?
Users browsing this forum: No registered users and 26 guests
