What should the compression be on an AE92 FX-GT 4AGE?
100 psi to low?
d1 mule wrote:low, the manual says 156 minimum. I did my ae92 4agze cold comp (not been run for months) was 155-160 across all four
strx7 wrote:d1 mule wrote:low, the manual says 156 minimum. I did my ae92 4agze cold comp (not been run for months) was 155-160 across all four
for cold compression, unless it had oil in the bores, that is some pretty high cold compression. some of the engines we get at work which hot test at 220-230 only cold test at 130-140.
