AVGAS
AVGAS
Postby avinesh » Wed Nov 18, 2009 6:15 pm
Hey guys just wondering if avgas is ok to run on a 2jzgte engine (stock internals)....car has been tuned on 98pump gas on haltech ecu an is making around 540whp, just wondering if its ok to run avgas without retuning for a couple of nightspeed dragwars meet.....wont be running pure avgas but mixed with 98 pump fuel, about quarter tank 98 pump fuel with about 18liters avgas.......
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby Flannelman » Wed Nov 18, 2009 6:17 pm
if you have cats, dont, otherwise its fine
Flannelman
formerly known as Affroman
Postby avinesh » Wed Nov 18, 2009 6:19 pm
Affroman wrote:if you have cats, dont, otherwise its fine
Dont have cats or o2 sensors.....just wondering if its ok to run avgas on a car tuned on 98 pump fuel......
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Toby » Wed Nov 18, 2009 6:24 pm
If you're tuned for 98 it wont make a hell of a difference.
Do it anyway, smells nice.
Toby
Postby avinesh » Wed Nov 18, 2009 6:27 pm
Toby wrote:If you're tuned for 98 it wont make a hell of a difference.
Yea just thought it would run safer on higher octane, dont really care much about power gains....an im getting it cheap.....
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Dell'Orto » Wed Nov 18, 2009 7:03 pm
Wont make SFA difference unless you alter anything, will be perfectly fine. Also if you have platinum/iridium plugs swap them out too, lead screws them
Postby avinesh » Wed Nov 18, 2009 7:13 pm
SFA did you mean it wont make any difference to engine running safer???
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Akane » Wed Nov 18, 2009 7:16 pm
Yeah he means it makes "sweet F all" difference.
Try get the 100LL (low lead).....
Postby avinesh » Wed Nov 18, 2009 7:28 pm
Akane wrote:Yeah he means it makes "sweet F all" difference.
Will the iridium plugs last one night speed meet?? I might pump the boost 1 or 2psi higher so thought it would offer a bit of safty....
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby QikStarlie » Wed Nov 18, 2009 8:26 pm
i used to mix it 50/50 with 98, in my old car. could tune it to run almost 10km higher trap speed, and run another 4psi boost. over straight 98.
so yeh should be fairly safe to throw some in, and run a bit more boost. long as there isnt anything silly going on with your tune, at higher manifold press.
if memory serves me right you need a bit more av than normal gas. because of the way its made. (pick up a 20l drum of pump gas then pick up a 20l of av) but in saying that, i didn't see a difference in the afr worth worrying about.
QikStarlie
Postby avinesh » Wed Nov 18, 2009 8:39 pm
QikStarlie wrote:i used to mix it 50/50 with 98, in my old car. could tune it to run almost 10km higher trap speed, and run another 4psi boost. over straight 98.
I was gona run a bit more 98 then avgas like around 24liters 98 an 18 liters avgas, what do you recon???
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Py7h0n » Thu Nov 19, 2009 11:26 am
I would not bother with the AvGas. If you are worried about your tune get it looked at but you can make a bit more power than 540whp on 98.
Py7h0n
Postby Lith » Thu Nov 19, 2009 12:21 pm
Total waste of time if you aren't adjusting the tune to suit, in my opinion.
If you want to start playing with fun fuels, get a tune for an ethanol blend...
2007 Mazdaspeed Axela
Lith
Postby avinesh » Thu Nov 19, 2009 12:27 pm
I just thought it would offer a bit of safty as its higher octane thats all.......im gettin it for the same price as 98 octane from a mate soo just wondering if i should just put it in since it wont cost me anymore......
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Bazda » Thu Nov 19, 2009 4:10 pm
Just put in some octane booster for some added safety. A $25 bottle will mix something like 100L +
I used straight av gas in my car, and it didn't like it. Went slower.
Basically I had to retune it if I wanted to run av gas. So I just kept with 98 and just run octane booster for piece of mind.
Postby avinesh » Thu Nov 19, 2009 6:19 pm
o ok.....was the loss in power noticeable bazda???
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Bazda » Thu Nov 19, 2009 9:09 pm
avinesh wrote:o ok.....was the loss in power noticeable bazda???
Noticeable enough for me not to use it unless I got a proper tune.
Postby Crampy » Thu Nov 19, 2009 9:38 pm
AVGAS is way higher octane than 98. If you're tuned for 98, use 98.
If you want to use AV, then tune for it.
Crampy
Postby matt dunn » Thu Nov 19, 2009 9:55 pm
A car that does not need the extra octane to prevent detonation will usually make more power on 98
as 98 burns faster than avgas and there is a long technical explanation why.
I run Avgas as I get it easier and cheaper then 98.
Postby avinesh » Thu Nov 19, 2009 11:04 pm
matt dunn wrote:A car that does not need the extra octane to prevent detonation will usually make more power on 98
What about a car that wants to run a psi or two higher??? And also 98 mixed with avgas lets say 60 percent 98 an 40 percent avgas, will it be 107 octane still or less like 101 or sumthing???
220.1 rwkw
jza80 supra = 11.7
avinesh
