Bov close to turbo
Bov close to turbo
Postby deaf_rattle » Wed Nov 18, 2009 8:46 pm
Any problems with running a plumb back bov close to the turbo?
thinking maybe having it mounting on the outlet of turbo, then plumbing back into intake pipe (between afm and turbo)
yay or nay?
Postby 79rolla » Wed Nov 18, 2009 9:06 pm
shuldint be an issue, my mate has his 180sx setup like that, no issues except his cheep turbo just killed itself but dont thinks its related to bov.
having bov like that could reduce intercooler heat soak (in thery) and reduce lag by not having as mutch of a vacuum in the inlet
past: AE82 FXGT
79rolla
Postby strx7 » Wed Nov 18, 2009 9:17 pm
it will be the laggiest set up possible after changing gears because when the BOV opens all the pressurised air between it and the throttle body back feeds to vent out the BOV. when the BOV closes you then need to pressurise up all the volume between the bov and the throttle body before you are back into boost
Postby deaf_rattle » Wed Nov 18, 2009 9:21 pm
ok, looks like ill need to run a hose/tube from the t/b side of the engine bay over to the intake! doh!
Postby fivebob » Wed Nov 18, 2009 9:28 pm
Should be fine, that's the stock SW20 set up and there are no issues with it even when using much larger turbos
Postby fivebob » Wed Nov 18, 2009 9:31 pm
strx7 wrote:it will be the laggiest set up possible after changing gears because when the BOV opens all the pressurised air between it and the throttle body back feeds to vent out the BOV. when the BOV closes you then need to pressurise up all the volume between the bov and the throttle body before you are back into boost
That doesn't make sense:?
Location makes no difference to the volume of air that the valve vents, and that is the air the will have to be "replaced" when the valve closes again, therefore there should be no detectable difference in lag.
Postby sergei » Wed Nov 18, 2009 9:36 pm
Also GT4 has BOV before intercooler.
Postby deaf_rattle » Wed Nov 18, 2009 9:36 pm
fivebob wrote:Should be fine, that's the stock SW20 set up and there are no issues with it even when using much larger turbos
do you have any pics of this set up?
the bov im running is nothing special, (bosch bov as used on porsche, saab etc) and not worth "showing off" so maybe hiding it away under the intake would be quite good.
Postby sergei » Wed Nov 18, 2009 9:42 pm
It plumbs where the yellow plug is, right next to inlet on the intercooler.
Postby FLAWLES » Wed Nov 18, 2009 9:44 pm
std vvti 1jzgte factory bov is straight after the turbo ( well on that big stupid manifold )
back feeds into the plenum type set up
and thats where my new aftermarket one will be going
FLAWLES
Postby loudstealthGT-Four » Wed Nov 18, 2009 9:49 pm
Read somewhere that the closer the bov is to the throttle body the better the response and the closer it is to the turbo the louder it is? True or BS
loudstealthGT-Four
Postby escortman » Wed Nov 18, 2009 10:12 pm
FLAWLES wrote:std vvti 1jzgte factory bov is straight after the turbo ( well on that big stupid manifold )
on my mates chaser he found it would struggle to run when that factory bov is unplugged
4x4 toyota blizzard offroader
escortman
Postby Coke » Thu Nov 19, 2009 12:25 am
Will it be a plumb back? I hear they run like shite if using a bov that vents because of the afm....ive got a vvti 1jzgte and thought about going aftermarket.
Coke
Postby matt dunn » Thu Nov 19, 2009 1:02 am
loudstealthGT-Four wrote:Read somewhere that the closer the bov is to the throttle body the better the response and the closer it is to the turbo the louder it is? True or BS
Makes sense so I'd believe that,
but 1/2 the people that are worth listening too say close to the turbo and the other 1/2 say close to the throttle.
I go close to the Throttle body,
as if it's pre-intercooler, the airflow through the intercooler is reversed when it's venting the pressure out, and then has to change direction again to re-pressurize.
I dont think it makes much if any difference either way though.
Postby strx7 » Thu Nov 19, 2009 6:53 am
I'm pretty sure that it actually does make a different to the volume of air, it certainly makes a difference to the pressure of charge at the BOV
With the BOV by the turbo, the intake charge is like a wave at the beach, back and fowards, with it by the throttle body, its like a stream. the intake charge keeps flowing in the right direction
I'm sure there would be some data somewhere which supports having it by the TB
where do WRC cars have it????
Postby fivebob » Thu Nov 19, 2009 7:22 am
strx7 wrote:With the BOV by the turbo, the intake charge is like a wave at the beach, back and fowards, with it by the throttle body, its like a stream. the intake charge keeps flowing in the right direction
Which makes it even more strange as by definition pressure waves move at the local acoustic velocity, which given the temperature and density of the air in the intake track is around 350m/sec. So in the time it takes the valve to open and close the pressure waves have travelled backwards and forwards a thousand times.
Sometimes using ones perception of how things should work leads to a misunderstanding of the realities of the physical world. Air does need to be flowing in any particular direction for pressure waves to move in that direction. A perfect example of this phenomena is exhaust systems, in particular two stroke expansion chambers, and despite the vast amout of research we still don't fully understand all the parameters that make them work.
Please note I'm not saying that BOV position has no effect, just that most likely the effect won't be measurable by the average seat of the pants dyno.
Postby iOnic » Thu Nov 19, 2009 8:07 am
Both Fivebob and strx7 are correct. "In theory" it's better to have the BOV closer to the throttle body so as to keep all the air mass flowing in the one direction. In practice......everything happens so quickly that you'll never notice the difference anyway.
Postby FLAWLES » Thu Nov 19, 2009 8:17 am
no not the kit that i am getting, ( sard r2d2 full jzx100 kit blocks off oem bov and moves the sard one away from the manifold )
read this it will help you alot
http://www.jzx100.com/forum/index.php?showtopic=1521
FLAWLES
Postby Malcolm » Thu Nov 19, 2009 10:11 pm
jeez I love hearing people claiming that "in theory" this is the case, when the theories that define the physical behaviour of many systems are highly complex and you can't easily draw conclusions as specific as "your BOV should be close to the throttle body" from them. As fivebob says, some physical phenomena can't be explained simply by what you think should happen, especially for fun things like fluid dynamics. The only real way to answer these questions is either through an assload of simulation and modelling (which may or may not be accurate), or better, physical testing and experimentation.
Postby sergei » Fri Nov 20, 2009 2:35 pm
BOVs are there to not make more power, but to save turbo. In this case in my opinion it should be as close to turbo as possible. Reasoning behind this - it will drain where it needs to drain.
But if you think the speed of sound and sound waves, the BOV opening will take thousands of times slower anyway.
Users browsing this forum: Google [Bot] and 2 guests
