Are HID Kits legal in NZ?
Postby furryfren » Thu Nov 19, 2009 9:41 pm
I see lots of HID kits selling on trademe but this I got from LTSA:
"HID conversion kits (an HID bulb with a high voltage power unit or ‘ballast’ which fits into the original headlamp unit in place of the original bulb with no change to the headlamp lens, reflector or housing) are illegal on any vehicle being used on New Zealand roads."
Help me understand if the kits from trademe are legal?
I was going to go with this one: http://www.trademe.co.nz/Browse/Listing ... =254178262
Image zhi-lee.com
furryfren
Postby Alex B » Thu Nov 19, 2009 9:48 pm
No not legal unless you replace the lends with an HID unit, like how some cars have HID's as an option, you could swap them over, but can't run them in a housing not designed for HID's.
Postby matt dunn » Thu Nov 19, 2009 9:50 pm
It is illegal to fit HID bulbs to a car that was not HID from factory.
Yes the trademe kits are Illegal for on roda use,
probably find that they have "for off road use only" somewhere on the box.
Postby furryfren » Thu Nov 19, 2009 10:01 pm
Thanks guys.
Image zhi-lee.com
furryfren
Postby NILPSI » Thu Nov 19, 2009 11:24 pm
If i remember correctly all HID equipped vehicles also have to have self height adjusting, and self cleaning headlamps (water sprayers)
May be wrong about the sprayers, but all the new cars that come through work with HID have them
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
Postby Akane » Fri Nov 20, 2009 1:46 am
HID lens housing is specially designed so the beams don't scatter etc, you'll have to google on that, it's a LONG read.
But if you ever decide to do it anyway, please readjust your housing to point down a bit more (I always do it), it doesn't blind people as much.
You can see on my avatar, you'll get blinded at that angle.
Postby Alex B » Fri Nov 20, 2009 9:19 am
NILPSI wrote:If i remember correctly all HID equipped vehicles also have to have self height adjusting, and self cleaning headlamps (water sprayers)
Don't know about that, my integra has them factory and has no water sprayers and I'm 90% sure they are just manual ajustment.
Postby sergei » Fri Nov 20, 2009 2:42 pm
What is the craze about HID?
Most HID kits I've seen come with direct bulb replacement. Due to design of the lens (for halogen), completely different focusing needed for HID.
If you drive with HID light bulb fitted into halogen lens, you are simply an inconsiderate asshole. Especially if you put those deeply blue hinted light bulbs.
As for superiority in spectrum and coverage - good halogen setup will outperform HID. HID have very poor spectrum, even expensive ones have huge drops and glow with a few very defined peaks.
If you think you can see better with blue light bulbs, you are mistaken. Blue lighting creates a lot of haze, and it takes longer for eye to adjust from blue lighting when blinded.
People with dyed blue halogens are simply inconsiderate assholes as well.
In case of lighting the safety definitely should come first, unless you don't plan to drive at night, ever.
Postby Akane » Fri Nov 20, 2009 4:25 pm
I wanna drive in opposing traffic with sergei. :lol:
Postby Elmo » Fri Nov 20, 2009 5:08 pm
I have over 400 watts of halogen head lamp power and I have no issues seeing at night :-D :-D
Elmo
Postby pidge » Fri Nov 20, 2009 10:03 pm
Elmo wrote:I have over 400 watts of halogen head lamp power and I have no issues seeing at night :-D :-D
I have that on my Dolomite - 2 x 120W High beam + 2 x 120W pencil beams. I think. Can see a loooooooong way down the road at night. Attract moths like $^&& though...
Unlike the puny 2 x 80W on my Levin :(
pidge
Postby sergei » Fri Nov 20, 2009 11:10 pm
You will find that having such large wattage light bulbs in Levin (I assume you have stock wiring) would make them dimmer/redder than 55W (or whatever comes from factory).
Postby Mr Revhead » Fri Nov 20, 2009 11:13 pm
You have a Dolomite? I demand pics!!
Postby Elmo » Sat Nov 21, 2009 6:31 am
I put 140/100's in my levin, bought the aftermarket wiring loom with the relays for it. It was beautiful.
I havent up graded the main beems on my truck as I have a tendancy to smash them, so keep them cheap! lol (although its just the lenses I smash, havent done a bulb yet)
Elmo
Postby sergei » Sat Nov 21, 2009 6:57 pm
Here, nice example of Dolomite
Image :lol:
Postby BlakJak » Sat Nov 21, 2009 7:52 pm
For the record, our FAQ contains an article on vehicle lighting
viewtopic.php?t=45506
Which contains a link to
http://www.landtransport.govt.nz/vehicl ... right.html
Which clearly states:
High intensity discharge (HID) conversion kits
However, a complete halogen headlamp unit can be replaced with a complete HID headlamp unit provided that the replacement headlamp unit complies with approved standards. If in doubt, get advice from a vehicle lighting retailer you trust.
BlakJak
Postby pidge » Sat Nov 21, 2009 11:03 pm
I stand corrected. I was guessing the high beam wattage... :oops:
pidge
Postby pidge » Sat Nov 21, 2009 11:30 pm
I'll admit "have" is debatable - I own it, but it's at the other end of the North Island from me :(
Trivia regarding the car:
- Was owned by Graham McDonald (Croydens Supra) a few owners back.
- Now hosting a TR7 engine, single rail OD gear box, Dolomite Sprint Rear Axle.
- and could have imported a recondition Dolomite Sprint from the UK for what I p*ssed away on it :(
pidge
Postby RunningRich » Mon Nov 23, 2009 10:09 am
Best place for any Triumph is the opposite end of the country (or planet)...
:lol:
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Mr Revhead » Mon Nov 23, 2009 3:32 pm
Hey Dolomites are cool!
Heralds on the other had....
